Dados and Tenons tight!
Terry Davis
Company Name: Penn Laminates
Postby Terry Davis » Tue, Jan 06 2009, 4:38PM
Over the past few jobs our dados and tenons have gotten very tight, to the point we had to use clamps to pull them together. We have changed no setting in Ecabs, what settings at the machine would effect this?
David Egnoski
Re: Dados and Tenons tight!
Postby David Egnoski » Tue, Jan 06 2009, 5:33PM
Are you checking material thickness on several sheets before cutting? I've seen pretty big differences in thickness in one unit lately.
Dave Egnoski
Richmond Cabinet & Millwork
Damon Nabors
Postby Damon Nabors » Tue, Jan 06 2009, 6:24PM
adjust your fit clearance
Damon Nabors
jerry johnson
Postby jerry johnson » Tue, Jan 06 2009, 8:14PM
Have you sharpened your bits? When you sharpen them they get smaller and you need to update your tool table. 8)
Damon Nabors
Postby Damon Nabors » Tue, Jan 06 2009, 8:52PM
True
Damon Nabors
Jon Dieterlen
Postby Jon Dieterlen » Tue, Jan 06 2009, 10:12PM
When tools get dull, they compress the wood fibers instead of cutting them. After the cut is made, the fibers spring back. Thus dadoes end up slightly smaller, and tongues slightly wider.
My hunch is, you need to sharpen the tooling.
Hope this was helpful.
Jon
Jody Wilmes
Company Name: Thermwood
Postby Jody Wilmes » Wed, Jan 07 2009, 9:07AM
Your daylight value could be wrong, making the tennon too thick or too thin. Check your wasteboard value too.
Double check your diameter set for the tool cutting the dado. As mentioned earlier, tool wear would cause the dado width to become too small.
Bill Madge
Postby Bill Madge » Wed, Jan 07 2009, 9:58AM
Check Controll nesting to make sure that you are set to conventional cut direction, climb cutting will cause diflction in the bit. This problem compounds as the bit becomes Dull. Second check your cut through, if it seems that your cut through doesn't quite match what you have set in controll nesting there may be an issue with your measuring device. I have had a similar problem and discovered that the arm on the measuring system was slightly off square to the machine, this may only affect your surfacing cutter because of it's large diameter and it being three wings. If you measure the surfacer multiple times turning it slightly between measurements you should see the daylight values change. Thickness of material will not affect the fit of the tennon as everything is referanced from the table.
FredHirsch
Postby FredHirsch » Wed, Jan 07 2009, 1:11PM
Terry,
All these are great suggestions. I think it could be any or all of the above. For this exact reason we don't use re-sharpened bits on the machine anymore. I've had the pleasure of sending out a bunch of KD furniture that the guys cut with resharpened bits and did not reset on machine. The phone rang off the hook for a couple days... and we learned our lesson very quickly. Keep your tooling sharp, we've learned it is not worth the cost and hassle with assembly and all the other problems that will ripple through the system.
Fred
Fred Hirsch
Joe Dusel
Postby Joe Dusel » Fri, Jan 09 2009, 11:10AM
Yeah, having RTA holes cut slightly small with re-sharpened bits is not good. That happened on a job done for me with $120/sheet plywood. Fortunately it was a small job and we were able to correct the problem the old fashioned way with a hand drill.
CFT411 http://www.cft411.com
JohnLashuay
Postby JohnLashuay » Fri, Jan 09 2009, 11:16AM
When you sharpen your bits can you measure the bit and input the reduced size of the bit and it will in turn CNC the proper size?
http://www.rylexonline.com
Thermwood CS 43
Todd Miller
Postby Todd Miller » Fri, Jan 09 2009, 1:16PM
JohnLashuay wrote:When you sharpen your bits can you measure the bit and input the reduced size of the bit and it will in turn CNC the proper size?
Joshua,
This will only work with programs that use a G41/G42 code to activate the radius comp. When code is generated it is written as a centerline cut. The G42/G41, when called, looks at the tool being used, sees what diameter it is by looking at the tool table, then compensates half the diameter.
HTH
Terry Davis
Postby Terry Davis » Mon, Jan 12 2009, 2:10PM
Problem solved! Jody you nailed it, it was a bad (fat fingers) wasteboard value, everything is cutting perfect again!
Jody Wilmes
Postby Jody Wilmes » Mon, Jan 19 2009, 10:42AM
Terry Davis wrote:Problem solved! Jody you nailed it, it was a bad (fat fingers) wasteboard value, everything is cutting perfect again!
Good to Hear!
Users browsing this forum: No registered users and 55 guests
