molding is being place upside down
I'm trying to place cove molding from the molding editor window and its being installed upside down. How can I flip the molding. I tried creating a separate cabinet with the molding on it and deleting everything but the molding so I can rotate and place on my original cabinet to create a assembly, but when I delete the last part of the cabinet the molding gets deleted along with it also. Need help.
Re: molding is being place upside down
If you remove the parts by unchecking them in Construction Settings you should be left with the molding.
- MOLDING.jpg (15.38 KiB) Viewed 3405 times
Thanks Rick,
That solved my problem
Patrick,
You might post a Feedback in the software to inform the programmers that a molding is being placed upside down in the Molding Editor so that they can fix it . Just tell them which molding and what you were doing with it.
