C tops
Jerry McClain
C tops
Postby Jerry McClain » Fri, Jan 30 2009, 3:59PM
I am wondering if anyone has a work around to get c tops to the LDE. I have to do shop drawings for a commercial job and when I put on the c top it shows it wall to wall. I have tried to edit the c top, tried to delete, and even went to the c top editor and back with making no changes. None of it seems to work. I do not want to have to resort to CAD. Help!!!
JLM
Todd Miller
Re: C tops
Postby Todd Miller » Fri, Jan 30 2009, 4:23PM
Jerry,
If you just want CT in the LDE.....
Select and delete all of the cabinets.
Select the LDE button.
Select the "Take Custom Layout" radio button.
Then select "OK".
You CT should appear in the LDE.
If this is not the answer you were looking for, let me know.
Jerry McClain
Re: C tops
Postby Jerry McClain » Fri, Jan 30 2009, 4:25PM
I have attached a doc to help show what I have going on.
C top issue.doc
(160.5 KiB) Downloaded 74 times
JLM
Jerry McClain
Re: C tops
Postby Jerry McClain » Fri, Jan 30 2009, 4:28PM
No it is showing the tops two different lengths depending on what view you are looking at and when I go with it to the LDE it shows the wrong one. Just my luck.
JLM
Todd Miller
Re: C tops
Postby Todd Miller » Fri, Jan 30 2009, 4:31PM
Jerry,
Post the .esj file, and let me take a look at it. Thanks!
Todd Miller
Re: C tops
Postby Todd Miller » Fri, Jan 30 2009, 4:40PM
Jerry,
Click and drag the entire run of cabinets plus the couter top. Select the wall, then click on the "view wall elevation" button. You should see the entire run of cabinets, the wall elevation, and the CT. Now click on the LDE button, and select "Take Wall".
Jerry McClain
Re: C tops
Postby Jerry McClain » Fri, Jan 30 2009, 4:51PM
Maybe this will help. The cabinets are 108' wide and in the overhead view such as when you are placing items it shows the c top correct but in the area, show wall view it is wrong. The top should be 109" not 226.5". I have emailed it to cabinets@thermwood.com and Justin is looking at it. Just didn't want you all to think I am crazy. :D
c top error.jpg (27.39 KiB) Viewed 1900 times
JLM
Re: C tops
Postby Rick Palechuk » Sat, Jan 31 2009, 1:21AM
Delete the top Jerry and make a new one.
Jerry McClain
Re: C tops
Postby Jerry McClain » Mon, Feb 02 2009, 9:23AM
I did that, and I even checked all the cabinets for ghost part editor cuts as well. I tried to edit the countertop, tried to change the overhang settings. I even made them a minus number to see what would happen and it went wall to wall no matter what.
Re: C tops
Postby DanEpps » Mon, Feb 02 2009, 10:08AM
Try deleting and re-adding the cabinet on the right. Something about one of the cabinets is most likely causing this.
You may have to start over and add the cabinets (and counter top) back on-at-a-time until you find the problem. After adding each cabinet, add the counter top and see if the length is correct. If it is, delete the counter top and add the next cabinet, etc.
Re: C tops
Postby Rick Palechuk » Mon, Feb 02 2009, 3:20PM
Post the job file Jerry, maybe we can help you find the culprit.
Users browsing this forum: Daniel Vonderheide, Ralph Balanik and 13 guests
