Second Computer Installation
Brandan Hanz
Company Name: H H Woodworks
Postby Brandan Hanz » Sun, Apr 12 2009, 8:20PM
My shop is out in the country and I currently do not have an internet connection there. Is there any way I can install ECabs on my shop computer and have it run properly without the application having to access the internet after installation? I'm getting busy now and really need the application at two different locations.
Brandan
brandan@hnhwoodworks.com
http://www.hnhwoodworks.com
Brandan Hanz
H & H Woodworks
San Antonio, Texas
Jeremy Schiffer
Re: Second Computer Installation
Postby Jeremy Schiffer » Sun, Apr 12 2009, 9:44PM
Hi Brandan,
Unless something has changed with the latest release, there is no way to use ecabs without hooking up to the internet on the first run so it can register. My suggestion is to carry your shop computer home or whereever you may have internet access and let it register from there.
No internet access is required from there on. Updates can be downloaded on another computer and brought to the shop computer.
Intel Core i7-5820 3.3GHz, 16GB RAM, NVidia Quadro K2200 4GB, Windows 8.1 Pro 64 bit
Postby DanEpps » Mon, Apr 13 2009, 5:28AM
Jeremy Schiffer wrote:...No internet access is required from there on. Updates can be downloaded on another computer and brought to the shop computer.
I'm not sure, but I think it checks for updates on startup. I see a "Checking for updates..." popup every once in a while.
Jeremy Schiffer
Postby Jeremy Schiffer » Mon, Apr 13 2009, 11:40AM
True, Dan. But if it doesn't detect an internet connection it pops up an error telling you there is no connection, and asks to either retry or cancel. If you cancel, the program starts normally.
Jeremy Schiffer
Postby Jeremy Schiffer » Mon, Apr 13 2009, 11:42AM
Just to add to my last post...
It doesn't check for updates (and therefore pop up an error message) every time you start the program. Only occasionally, like once a month or less.
Postby DanEpps » Mon, Apr 13 2009, 12:46PM
I wasn't sure what would happen if you weren't connected when it checked. I did know that it does not check every startup but I didn't know how often it was.
Users browsing this forum: No registered users and 11 guests
