Partition and shelf pin holes
Patrick Russell
Postby Patrick Russell » Wed, Apr 29 2009, 8:26AM
Have a question on applying shelf pin hole on both sides of a partition.Is the integrate of the partition weaken and if it is how do you avoid this? Do you but another partition to it or off set the shelf pin holes on one side? Thank you
JohnLashuay
Re: Partition and shelf pin holes
Postby JohnLashuay » Wed, Apr 29 2009, 8:44AM
Patrick Russell wrote:Have a question on applying shelf pin hole on both sides of a partition.Is the integrate of the partition weaken and if it is how do you avoid this? Do you but another partition to it or off set the shelf pin holes on one side? Thank you
Patrick,
The integrity of the partition should not be weakened just by adding shelf pin holes to both sides, if you are using 3/4" material or even 5/8" this should be fine.
-John
http://www.rylexonline.com
Thermwood CS 43
Damon Nabors
Postby Damon Nabors » Wed, Apr 29 2009, 1:05PM
One thing to remember on thinner material. If you are placing shelf pin holes on both sides and wish to have your shelving level across the cabinet. The length of the pins may interfere with each other. I try to stay with 3/4" for center partitions to avoid this problem.
Damon Nabors
Users browsing this forum: No registered users and 19 guests
