won't nest whole job
- Company Name: Heritage Woodcraft
Hi
I have desig ed a complete kitchen in the custom layout but when I try nest it only some of the cabinets nest. I get no error message or parts won't nest. It acts as if it only sees about half of the job. When I try saved jobs it works.
thank you
Lorin
thank you
Lorin
Re: won't nest whole job
In case it makes a difference the cut list is complete and individual cabinets nest.
thanks again
Lorin
thanks again
Lorin
Did you check the filtering to see if for some reason some of the cabinets are turned of in there
Iain Hall
Woodwright Cabinets
Woodwright Cabinets
I checked this now and all the cabinets are checked. I think it is actually nesting 6 or 7 of the 20.
Thanks for this advice. I had never used the filter before.
Lorin
Lorin
That uses up all I know there are others here that can make E cab dance if they want to. I know just enough to be dangerous.
Iain Hall
Woodwright Cabinets
Woodwright Cabinets
Ian,
Did you try re-starting your comoputer and then nest the job?
Post your job so we can try to nest it.
Thanks for the help. Your email got me straightened out Kerry.
OK Kerry, spill it. What was in the email that made things all better.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
I had to delete the toe kick on one cabinet. I am not sure why, but it worked after this.
Lorin
Lorin
