'Ramped' Pockets?
Nat Wheatley
'Ramped' Pockets?
Post by Nat Wheatley »
Is there a way to create a pocket with a 'ramped' bottom? I'd like to create slots for pocket screws on several of my parts. The bottom of the slot would be about 3/8" deep at one end, and ramp up to the surface of the material at the other end.
Re: 'Ramped' Pockets?
You mean like this Nat?
Pocket Screw.jpg (23.88 KiB) Viewed 5196 times
If this is what you are looking for, here is a visual explanation of how to get these results:
Pocket Screw How-to.jpg (37.51 KiB) Viewed 5187 times
pocket Screw Bottom.jpg (42.3 KiB) Viewed 5187 times
Pocket Screw Top.jpg (42.39 KiB) Viewed 5187 times
...and here are the tool files:
Pocket Screw.zip
(2.49 KiB) Downloaded 273 times
Larry Epplin
Post by Larry Epplin »
Something that should be mentioned here Nat. Dans, method here would result in Profile Modeler operations. The ShopBot Link does not support Profile Modeler. There is not a way to create ramped pockets that will cut with the ShopBot Link.
Sorry...didn't know Nat was a 'Botter and this method wouldn't work for him.
Nat Wheatley
Dan,
Thanks very much for taking the time to post. Sorry not to have mentioned that I was using the SB Link, I didn't realize that it would factor in.
Nat
I didn't know it would make a difference either.
