When specifying to leave a skin or tabs on small parts, which takes precedence - skins or tabs? In other words, if I make skin and tab parameters the same - width, square inches, etc, which is SB Link going to use to hold the part in place?
I'm using SB Link 1.0.12.
ShopBot Link - tabs or skin - which takes precedence
Re: ShopBot Link - tabs or skin - which takes precedence
Hi Don. The 2 features work independently. You can have both tabs and leave a skin at the same time.
Thank you Larry.
So if I set up to have tabs and skins, will the skinning operation route away the tabs or will the skinning operation leave the tabs in place?
The tabs will remain.
Thank you Larry!
SB Link is pretty intelligent.
