I'm running version 1.0.12 of SB Link and have noticed something I'm not sure is right or wrong. I have ramping setup at 1.5". When the machine is doing dado cuts, there are times that it will perform this ramp when entering the material and other times it just plunges to full depth and starts cutting the dado. This seems to happen in both long and short dados. Also, somethings on long dado cuts it will perform a gradual ramp the full length of the dado. At the end of the first pass it will be a final depth. With this type of operation, each dado takes 3 passes to cut. All this behavior is happening on 3/4" plywood.
Not sure what I have setup wrong or what. Any help would be appreciated.
Thank you.
Shopbot Link - Ramping issue
Re: Shopbot Link - Ramping issue
Further information on this, I noticed that ramping is working properly on all outline cuts - both on the first pass and the second pass.
I have noticed, however, that on dado cuts ramping is very random in whether it happens or not. As mentioned in the first post, sometimes a ramp operation is performed the full length of the dado and other times it simply plunges to full depth and starts cutting. I wish I knew if or where this is controlled in SB Link settings and I would turn it on for all dado cuts.
Can you email an import from the link to program@thermwood.com so we can try to duplicate the error?
Daniel,
I will get it emailed to you as soon as I get a breather.
- Company Name: Ernest Klassen Kitchens
Yes I have noticed that too. It makes for extra passes on the blind datto cuts.
Another thing I have noticed is that the X,Y move speed and the Z move speed are locked together.
When the X,Y move speed changes to a slower speed, to cut small parts, the Z move speed changes to
the same speed.
the same speed.
- Company Name: ShopBot Tools Inc
Don & Ernie...
I can't give you the definative answer here, but I sent in a file a while back with the same "extra pass" and speed questions. The software may have changed since then, but here is what I was told, and it makes sense to me.
The extra pass is a result of a cleanup for the ramp in section of the dado. Larry was going to look at this and see if it was doing what what was intended.
The speeds all going to the same are also "common" on the big iron. G Code sets and/or changes move speeds much more often than we are used to with vector based CADCAM software. I consider this a plus. Your 3 axis move speeds are set for a part, and since there is always a ramp in, even if they were the same, the ramp would be no greater angle of entry than 45 degrees. In most cases, you set a longer ramp length and the z actually takes the full distance of the ramp to penetrate to the cutting distance. So even if your console displays a faster than you would like speed number, it will rarely move that fast. Z speeds are set by interpolation to match the ramp length. Straight plunges and retracts use the Z speeds assigned to the tool.
Hope this helps and I didnt step on toes.
Gary Campbell
Users browsing this forum: Ahrefs [Bot] and 12 guests
