Dumb as a Rock?
Dumb as a Rock?
I must be dumb as a rock. I never use inset doors, but for the first time have an application and cannot find where to set the option for the cab doors to be inset. The help info refers to setting this option, but does not disclose where it is hidden. I'll bet someone is going to tell me it is right in front of me. Where is it?
regards,
regards,
Re: Dumb as a Rock?
OK, OK, I figured it out, but there really is no specific check-off box to make the doors inset. DUH
regards,
regards,
Re: Dumb as a Rock?
I do have a question, what should I allow as a standard all-around spacing to allow for door movement not to bind on the face frame when opened and using Blum hinges.
Thanks.
regards,
Thanks.
regards,
Re: Dumb as a Rock?
Hi Peter,
3/32 is pretty common, you can back bevel your doors and this also helps..
Mike Murray
mike@versatilecabinet.com
Re: Dumb as a Rock?
Michael,
I am assuming 3/32 on each side, correct?
regards,
regards,
Re: Dumb as a Rock?
Yes sir, 3/32" gap all the way around..
Mike Murray
Re: Dumb as a Rock?
damn phone......
damn phone......
Mike Murray
Re: Dumb as a Rock?
Absolute minimum is 5/64". And I really like the look of this spacing much better than 3/32".
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Re: Dumb as a Rock?
Got to be 11/128".
Re: Dumb as a Rock?
A wise guy in every group.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Re: Dumb as a Rock?
Peter,
What type of hinge are you going to use ?
Re: Dumb as a Rock?
Gary,
I plan to use a Blum hinge. Cab will be face framed.
regards,
regards,
Re: Dumb as a Rock?
Peter,
3/32 will be just fine, if you were going to use a furniture type barrel hinge then that's a different story.
Re: Dumb as a Rock?
Gary,
I spoke too soon. Since I answered your query, Client decided to use an finial hinge with mortised hinge plates.
Only a few doors are inset. All the rest are non-mortising finial hinges on an overlap door.
regrads,
regrads,
Re: Dumb as a Rock?
Peter,
You can get the inset finial hinge in a non motise I use them all the time.
- 31183-is1[1].jpg (4.2 KiB) Viewed 9902 times
