Printing Problem
Zach Froble
Printing Problem
Post by Zach Froble »
I had a problem with our printer last week and had to reinstall it. Now when I go into the line drawing editor it gives me a message to make sure the printer setup is correct. I went to the file menu and clicked print setup but nothing came up. I tried printing but nothing is working. I can print from other applications.
Anyone have any suggestions.
Zach
Lyndan Designs
Machining and CAD Services
Gary Puckett
Company Name: The Woodworkery
Re: Printing Problem
Post by Gary Puckett »
Zach,
Try shutting down your computer and printer and then restart them both.
Try going to the manufactures site and getting the latest Drivers.
Zach Froble
I tried restarting and the installed the latest drivers. The funny thing it was working fine and is still working fine with other applications. It is only Ecab that is giving me the problem.
Any other suggestions.
Zach
Lyndan Designs
Can you print from the Cost Sheet or Buy List? Is it just the LDE that wont print?
Are you using Vista Zach? I know some folks have had similar printing problems with Vista.
Zach Froble
I can print from the buy list and cut list, but I am still getting the same message when I open up the LDE. It is still telling me to check the print setup, but when I click on print set up nothing happens.
I am still using XP.
Zach
Lyndan Designs
Are you checking print setup via eCabinets (File->Print Setup)?
Zach Froble
Dan,
I tried clicking on print setup while in the line drawing editor, but nothing comes up on the screen.
Zach
Lyndan Designs
Scott G Vaal
Post by Scott G Vaal »
Zach,
Try deleting the file { DrawingsPrinterSettings.ref } from your eCabSys install directory and then try to print from LDE.
Zach Froble
Scott,
That solved the problem. Thanks everyone for the help.
Zach
Lyndan Designs
