built-in bookcase
Dana Sherry
built-in bookcase
Postby Dana Sherry » Mon, Jan 09 2006, 5:15PM
Hey, just wanted some advice- attached is a built - in which is destined for my living room wall, as shown. But FIRST, I need to display it at our local builders show. I want to set it up in my 12x12 booth without having to build a2x4 wall, set a window etc... soo, I was thinking it would look good against the 8' curtain in my booth, but I would like to \"tie it all together\" with an arched valance at the show perhaps, although it would simply be two seperate cases once in my living room, with crown returned into the wall. My question is, what type of valance do I build that is cost-effective (since it will not be used in the final resting place), or does anyone have ideas other than a valance that will make the piece look good as displayed at a show?
built in bookcase living room.jpg (85.76 KiB) Viewed 2455 times
EdDobson
Postby EdDobson » Mon, Jan 09 2006, 8:03PM
Hi Dana,
Nice set up. first I'd ask if you do many shows? If so, perhaps a piece you could re-use as something else. Just add an additional tier over the top with low voltage or battery operated lighting to highlight your work. Or for simplicity, you could just run a 5/4 top bullnosed over crown over 1X facia The additional piece could be re-used as above or as a display table in the future.
Ed
Postby George Davidson » Mon, Jan 09 2006, 11:07PM
Something to look at
This is 11' Wide for booth
Just one way
Back to the wall
Postby George Davidson » Tue, Jan 10 2006, 6:26AM
What about 1/4\" ply with crown. It would be very light
Postby George Davidson » Tue, Jan 10 2006, 7:01AM
Some more to look at
Pictures of your jobs
Dana Sherry
Postby Dana Sherry » Tue, Jan 10 2006, 3:20PM
Thanks George for the great ideas! Below is my improved display, complete with \"curtain look\". I think with some soffit lights in the valance it will be quite an eye-catching display. Which Brewster file did you get your curtain look from?
Dana
Builders Show display.jpg (150.81 KiB) Viewed 2378 times
Postby George Davidson » Tue, Jan 10 2006, 4:56PM
It will be quite an eye-catcher
Good luck at the show
KCDw program
EdDobson
Postby EdDobson » Tue, Jan 10 2006, 6:33PM
Great accents George!,
I'm a new member and anxiously awaiting the program in the mail. Also just scrolling through the past posts enhances my ability to provide clients with fresh ideas. Thanks
Ed
Return to “Customer Images”
