Does any body know how to make two doors on ecab? I want the panel one knid of wood while the rails are a different kind.
Bob
need help making Two tone doors
- Jean G Voyer
You have to use a regular door and align a display cube or panel to it.
It won't be exactly like you want but it will be close.
You can also use a frame and bring a display cube in the center or make a raise panel out of a assembly of display cubes.
I use this kind of technique to make speaker grills.
I hope this help.
I hope this help.
Jean-Gabriel Voyer
Janot Interiors Ltd
www.customcabinetscalgary.com
Janot Interiors Ltd
- George Davidson
I had to try one
My setting
Over (-2\") Change to what ever your frame is on the cab. my was 2\"
Inseat (.7656)
I think I went the long way a round
The 2 nd Cab. I made the size of the door.
Cab. 24 x 34.5 x 24
2nd Cab. 21\" x 27.75 x 2 Deep
That is how I got the outer rail & Stile to change color.
My setting
Inseat (.7656)
Cab. 24 x 34.5 x 24
Last edited by George Davidson on Fri, Feb 24 2006, 7:47AM, edited 3 times in total.
- Kerry Fullington
cabinetbob
This isn't great either but I did these using a slab door with a 2 1/4\" banding stock.
A Door Designer is supposed to be in the works at eCabinets which would probably let you do what you want with a five piece door but that is in a future release. For now maybe this would work.
- test.jpg (169.43 KiB) Viewed 7146 times
