Thermwood / eCabinet Systems • View topic - need help making Two tone doors
  • Advertisement
Moderator: Jason Susnjara
Postby cabinetbob » Thu, Feb 23 2006, 9:46PM
Does any body know how to make two doors on ecab? I want the panel one knid of wood while the rails are a different kind.
Bob
cabinetbob
Postby Jean G Voyer » Thu, Feb 23 2006, 9:52PM
You have to use a regular door and align a display cube or panel to it.
It won't be exactly like you want but it will be close.
You can also use a frame and bring a display cube in the center or make a raise panel out of a assembly of display cubes.
I use this kind of technique to make speaker grills.
I hope this help.
Jean-Gabriel Voyer
Janot Interiors Ltd
www.customcabinetscalgary.com
Jean G Voyer
Postby George Davidson » Fri, Feb 24 2006, 7:05AM
I had to try one
My setting
Over (-2\") Change to what ever your frame is on the cab. my was 2\"
Inseat (.7656)
I think I went the long way a round
The 2 nd Cab. I made the size of the door.
Cab. 24 x 34.5 x 24
2nd Cab. 21\" x 27.75 x 2 Deep
That is how I got the outer rail & Stile to change color.
Last edited by George Davidson on Fri, Feb 24 2006, 7:47AM, edited 3 times in total.
Postby cabinetbob » Fri, Feb 24 2006, 7:17AM
Thanks.....not what I had in mind. Seems very tedious. But I guess that will work.
cabinetbob
Postby Kerry Fullington » Fri, Feb 24 2006, 8:00AM
cabinetbob
This isn't great either but I did these using a slab door with a 2 1/4\" banding stock.
A Door Designer is supposed to be in the works at eCabinets which would probably let you do what you want with a five piece door but that is in a future release. For now maybe this would work.
Company Name: Hightech Cabinets
Postby Robert Spano » Tue, Feb 28 2006, 8:21AM
Thanks everyone. I appreciate your input. I'm looking forward to the new upgrade in ecab. I like the two tone doors. I hoping there was a file I can edit. But...were all cabinet makers / woodworkers. Not programers! lol... :lol:
Robert Spano
Return to Customer Images
