Cherry Gun Display Case
Postby DanEpps » Mon, Sep 18 2006, 12:21PM
This was inspired by Mike Seisser's Cherry Display Niche. If I were to build this it would be recessed into the wall and the box itself would be steel bolted to the studs and covered inside with veneer.
The door would also be steel with laminated glass and cherry appearance moldings.
Built without all of the steel it could be used to display anything.
Cherry Gun Display Case 2.jpg (14.24 KiB) Viewed 1130 times
Cherry Gun Display Case 1.jpg (15.31 KiB) Viewed 1130 times
Mike Seisser
Company Name: NCB Inc.
Postby Mike Seisser » Mon, Sep 18 2006, 12:32PM
Dan,
I don't know which is cooler, your design that incorporates the beauty of the wood along with the security of the vault or the fact that I inspired you.....
Can't wait to see it built.
Mike
Re:
Postby DanEpps » Mon, Sep 18 2006, 12:40PM
Mike Seisser wrote:Dan,
Mike
The inspriation Mike, the inspiration 8)
Return to “Customer Images”
