Paint Grade Job
Brian Shannon
Paint Grade Job
Postby Brian Shannon » Thu, Nov 23 2006, 12:42AM
This job will be painted white, then glazed. I'm working on hood now. The raised panels on the Penninsula back and Finished ends were cut on the Thermwood Router. I will also cut raised panels for the appliances on the router. I finally talked them into deleting the island. No room! This was a painin-the-_ _ _. The penninsula is a 147 degree angle to match the soffit.
Brian Shannon
Real Photos
Postby Brian Shannon » Thu, Nov 23 2006, 12:48AM
Rhea Job
Brian Shannon
more
Postby Brian Shannon » Thu, Nov 23 2006, 12:53AM
more
Brent Bogardus
Postby Brent Bogardus » Fri, Nov 24 2006, 2:05AM
Very nice Brian. I was expecting you to say you cut the corbels and the crown on your router too. I like the way the corners look where the crown meets. How did you do that?
Peter Walsh
Postby Peter Walsh » Fri, Nov 24 2006, 3:31PM
Brian,
I too like how you installed the crown. Very nice touch.
The counter top on the breakfast deck looks very thin compared to the massive support corbels. Are you going to add a face trim to thicken the edge impression?
Brian Shannon
Postby Brian Shannon » Sat, Nov 25 2006, 12:27AM
I felt I needed to make some transition corners for the Vinyard carved crown because there is no way to match the pattern. They are made of 2 pcs of 3/4\" MDF w/ a v-groove down the middle and a colonial route on each side. I thought about building up the counter sub-top with a skirt but it is an odd radius and would just be more work to give away on this job. They are putting on a Granite top.
Postby Rick Palechuk » Sat, Nov 25 2006, 10:20AM
Who gets to put the finish on?
Peter Walsh
Postby Peter Walsh » Sat, Nov 25 2006, 12:36PM
Brian,
Yeah, I see.
I zoomed in and see that is not the finished top that I thought at first glance at the pix. The granite guys will lip that nicely I suspect.
Still like the work though, customer should be happy.
regards,
Brian Shannon
Postby Brian Shannon » Sat, Nov 25 2006, 1:43PM
Thanks Guys,
Around here, the Painter/Finisher puts the finish on on-site. I'll post pictures when it is complete. That could be a while. I first bid this job in January '05. They actually wanted credit for deleting the 26 x 42 island that I said wouldn't fit since day 1. This penninsula was such an odd radius and angle that I made a .dxf(actually .tol) of the whole room outline to match the soffit. I then just bumped(moved) my lines over 7\" for my 41\"tall wall. That was the back of my cabinets. I used this Master to cut my decks and rough top. It's amazing what you can do in eCabinets.
Return to “Customer Images”
