New user 1st attempt
Ok so just got the program on monday. I must say i love it so far now if i could just learn to find and insert some display items from the stl folder \"which i cant find\". But anyways here goes. The finish Book case is in the garage er Shop as i type should be installed soon as i get someone to help will post final pics then.
- Book2.jpg (92.34 KiB) Viewed 7516 times
Nice job on the book case. The stl files need to be converted to hsf files before you can use them. I suggest you go through the tutorial type manual \"eCabinets Made Easy\" It will help a lot. Also whenever I have a question I do a search on this forum and usually find the answer.
When I opened my own shop a little over a year ago I was ready to drop over $7,000.00 on a cabinet program, (that didn't do everything ecabinets does) when I found out about this software. I haven't looked back and breath a big sign of relief for saving seven grand.
Good luck and happy designing.
Lamar Horton
