Finished job
Finished job
This is part 2 of my first post,, also finished today. This corner entertainment cabinet is in the kitchen/dining room. It is made of reclaimed longleaf (heart) pine, heavily distressed,clear finished and glazed with vd brown. The style of the home is southwest hacienda. I used ecabs just to get my proportions right and for my sheet goods count. The tv pictured is a 46, but the cabinet is made for a sony 52 which is coming later. Behind the lower doors are 3 drawers, and 3 component shelves. This cabinet houses the amplifier for the whole house system.
Mike
Mike
- Corner design.jpg (24.41 KiB) Viewed 17813 times
- reynolds 028.jpg (123.29 KiB) Viewed 17812 times
- reynolds 013.jpg (136.57 KiB) Viewed 17807 times
Re: Finished job
Michael, That is very sharp. Great work, I really like the top section. Did you build the arched doors?
Re: Finished job
Hi Michael
Like Joe said that is very sharp
- Company Name: NCB Inc.
Re: Finished job
Awesome look! The doors are just right. Your attention to detail makes this thing sing............
Are those strap hinges on the doors?
Re: Finished job
Thanks for the comments guys. Mike, they are strap hinges, rusted steel, probably some kind of acid wash. found them at Lee Valley. Joe, I did make the doors. They are all just 5 pc. doors. On the top doors, I cut all the individual pieces 1/2" thick, glued them into a panel, cut to shape, then rabbeted the edges to fit into the rail and stile groove. Same for the bottom. funny thing about this cabinet was that it was originally designed to fit the tv you see. 2 days after I started building, the owner called and said that he decided to upgrade to a 52", this one being 46. I panicked at first, but when I got the specs I saw that the 52 was only 3 1/2" wider so I just had to cut down the left and right stiles of the middle section. I don't think it hurt the look. Also, both middle side panels are actually doors that open to allow access to the backside of the tv.
Mike
Mike
Re: Finished job
Those access doors are a brilliant idea Mike.
- Company Name: AVBN
Re: Finished job
Nice work Mike! Love your top doors with the crown molding, look a bit Mexican style!
The plan as been upgraded a bit and the results are very good!
Francis
Francis
Re: Finished job
Hi Michael,
Mind if I ask how you angled the sides of the cabinet in your Ecab rendering. I have been trying to figure this out for some time. I am currently bringing in display boards and angling them in place.
Thanks!
Nick
Thanks!
Nick
- Company Name: Expressions in Wood
Re: Finished job
Looks like a standard corner cabinet with angled front.Nick Sollecito wrote:Hi Michael,
Thanks!
Nick
Re: Finished job
Nick
Glenn is right. Load a standard corner cabinet and open construction settings/corner settings/angled front. Once loaded click the blue arrow in the upper corner ot cabinet editor and adjust your dimensions.
Mike
Mike
Re: Finished job
Thanks guys. That seems to work.
Re: Finished job
I'm back again. I can't seem to figure our how to get the face of the cabinet flat like you are showing. I can only seem to adjust the depth of the angle.
Re: Finished job
I got it! I guess I'm a little dense. Thanks again!
