Hidden sound system
Francis Samson
Hidden sound system
Postby Francis Samson » Tue, Feb 12 2008, 6:38AM
This one was a bit tricky! First the guy who build the stone wall ended up with a 1 1/2 tapered front to back :fire:
And then i had to ventilate the sound system area because of the two amps! Ok easy work, first beat the mason! Then, build a two fan down draft with heat sensor in the back of cabinet and exhaust from the toe kick! Works perfect !
Terry Davis
Company Name: Penn Laminates
Re: Hidden sound system
Postby Terry Davis » Fri, Feb 15 2008, 7:14PM
Nice job Francis, where did you get the heat sensor your fans?
Francis Samson
Postby Francis Samson » Sat, Feb 16 2008, 8:36AM
Got the kit of fans and sensor at a store called Addison electronics.
It actually works really well and keeps the system cool.
I install this on every units that contains sound system and mostly with the plasma that are inserted in a cab! The kit of fans and electronics runs about $35.00cdn.
Ciao
Francis
Return to “Customer Images”
