Playing with some pull-outs.
How about some accessories?
- acc_01.jpg (301.76 KiB) Viewed 7925 times
- acc_02.jpg (241.82 KiB) Viewed 7930 times
- acc_03.jpg (277.36 KiB) Viewed 7923 times
Re: How about some accessories?
Remarkable...
I must admit the cabinet design had me from the start. But there is much more here than meets the eye.
Dan said it before "using common parts in uncommon ways". It is so evident in the use of so many nice objects to stage this scene.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
32Gigs DDR4
Corsair RM650
Michael,
I notices that Rev-A-Shelf had CAD downloads for all of their products so I am playing with them. This job used several of them so I started there. The only problem with the downloads is that you have to explode them in CAD then save different parts to layers and then convert them to use in eCabinets. It is a time consuming process. I am just doing them as I use the products.
It is nice though, because I can add a cost to them and add that cost as a cut list part when I insert the display object into the job.
Thanks for the information.
Again KUDOs to you.
Again KUDOs to you.
32Gigs DDR4
Corsair RM650
32Gigs DDR4
Corsair RM650
Kerry- BIG kudos to you on the Alver kitchen work, and the one here where you are "experimenting" with Rev-A-Shelf add-ins and accessories. You've obviously got the 'process' of converting CAD files to objects usable in eCab down. I'm sure the process is quite tedious and time consuming (though knowing what to do in the first place helps an awful lot !)
I wonder if these conversions, especially of things available thru the co-op, couldnt be done by Thermwood, or maybe they could work us up a semi-automated process to use in doing it ? Then lots more of us could more easily use them to "jazz up" our designs and presentations.
I'm still a very newbee and it's difficult enough to get moderately proficient with the basics of the program, much less the nuances that you've mastered. I keep grinding away because I realize how valuable the design freedom is ( and because, like most I suspect, I'm a techie at heart). People buy this stuff that we make because they like what they see. That's why they will buy a car for $20, $30 $40,000 or more straight out of a showroom, maybe without even driving it more than ten minutes.
I suspect that many users, like me, are 1-man-bands with no showroom, just photos of previous work. Showing a client a photo-real representation of what their project will look like can often make the difference and seal the deal.
I know the Thermwood folks must concentrate primarily on the design functionality and Cam-interface aspects of eCab, but the easier it is for us to present attractive, feature-rich designs to clients the more of them we'll sell, and the more money everybody will make
