Can someone help change these into STL please
Thanks in advance for any help... or if you can make them ready for use in the program
- m2510195_DEDO130.zip
- (70 KiB) Downloaded 591 times
- m2510449_VMOC205.zip
- (606.36 KiB) Downloaded 570 times
- m2510513_DECU165.zip
- (57.55 KiB) Downloaded 559 times
Re: Can someone help change these into STL please
Here is 2
- EC_STL.zip
- (276.46 KiB) Downloaded 574 times
Jason,
Were all of these .dxf's supposed to be of the same Viking Label?
They are suposed to be viking appliances?
Why when I assemble these are they all black? What am I doing wrong?
You have to put your own color in
Multiple Textures on the Same Display Part
Once a Display Part Editor file is loaded, it will need color, texture and a general "look". This software also has the ability to display complex objects that have different color and texture on different parts of the object. This is accomplished by generating a different ".stl" file for each portion of the object, loading each ".stl" file into the Display Part Editor, positioning them with respect to each other and then selecting and texturing each portion separately
- Shot1.jpg (74.07 KiB) Viewed 11725 times
But how do you make stainless steel color, It doesnt look right?
- Shot3.jpg (56.85 KiB) Viewed 11722 times
- Shot4.jpg (69.6 KiB) Viewed 11722 times
Here is one I just used From Viking
Gas Range 42" W
Gas Range 42" W
- 1.jpg (65 KiB) Viewed 11712 times
- 2.jpg (75.43 KiB) Viewed 11712 times
