Help? DXF to STL
Company Name: Halls Edge Inc
Help? DXF to STL
Postby Josh Rayburn » Thu, Sep 30 2010, 12:47PM
Anyone have a recommendation for a program I could use (preferably free) to convert this ISO30 toolholder dxf file into a stl to work in e-cabs?
Thanks in advance,
iso 30 toolholder 3d.zip
(407 Bytes) Downloaded 225 times
Re: Help? DXF to STL
Postby Kerry Fullington » Thu, Sep 30 2010, 7:02PM
Josh,
I use Accutrans 3D
It is just $20
I couldn't open your dxf with accutrans or Intellicad or deltacad
Postby Josh Rayburn » Fri, Oct 01 2010, 6:13AM
Kerry, does Accutrans 3d open IGES files too?
Postby Kerry Fullington » Fri, Oct 01 2010, 6:34AM
Josh,
Accutrans doesn't read or write iges files. I have never run across the iges format. What are you getting them from. You could open them in AutoCad and export as a 3ds.
Postby Josh Rayburn » Fri, Oct 01 2010, 6:56AM
Kerry, I've only got AutoCad LT which does not do 3d - I created that file in BobCad and just saved it off as a DXF. IGES is one of the most popular 3d file formats so I'm told, but I haven't had any experience with IEGS files myself. I do very little in 3d if not working in ecabs. Whole different ballgame.
Well anyhow, what other file formats does Accutrans read? Would it read a Rhino file - .3dm by any chance?
Postby Kerry Fullington » Fri, Oct 01 2010, 11:08AM
Josh,
HERE is a link to the files Accutrans reads and writes.
Postby Josh Rayburn » Fri, Oct 01 2010, 11:58AM
Cool, thanks Kerry.
I'm still too cheap to buy it just to entertain myself with having an ISO tool holder that I can render in my new toolholder cabinet though...
Next time the need arises (the need, not just the want) I'll surely purchase Accutrans based on your good review :D
Thanks again!
Postby Kerry Fullington » Fri, Oct 01 2010, 6:53PM
Josh,
I would convert it for you but there is nothing there when I open your file.
Have tried Via Cad, Intellicad, Accutrans, DeltaCad, and Alibre and there is nothing there. (your zip file is only 407 bytes)
If you can verify the file and send it to me or post it here I will convert it for you.
Postby Josh Rayburn » Mon, Oct 04 2010, 7:20AM
Hi Kerry,
Thanks - I tried to convert it from a solid to lines - don't know if this makes a difference....I appreciate the offer - let me know if this one works?
Thanks!
(29.8 KiB) Downloaded 206 times
Postby Kerry Fullington » Mon, Oct 04 2010, 7:46AM
Josh,
I am still no help. When I try to convert either of your files using Accutrans or ViaCad I get an error no meshe objects displayed. Your line drawing is 3D but has no surface meshes. Where did you get the drawing?
Postby Josh Rayburn » Mon, Oct 04 2010, 8:49AM
Hi Kerry,
I drew it myself - I measured one of my toolholders, drew the outer profile, then wrapped it around the center to make the solid.
I extracted the edges on the last one to attempt to get some simple geometry into the file in case that was helpful, but apparently not... :(
It must have been a problem with the way I created it - but I don't know what else to try...
Thanks for trying again - if you have another tip for creating it in the first place, I'll give it another go -
Postby George Davidson » Mon, Oct 04 2010, 10:24AM
Here it is in a STL all one pice
iso 30 toolholder STL.zip
(175.08 KiB) Downloaded 212 times
Postby Josh Rayburn » Mon, Oct 04 2010, 11:03AM
George -
You da man!!
Thanks very much, and thank you Kerry for trying! Much appreciated!
Audrey Racine
Postby Audrey Racine » Mon, Nov 08 2010, 7:15PM
Hello!
If you are using Autocad this can help you. juste write "stlout" and follow what is written and things will be fine!
Audrey
Dennis Englert
Postby Dennis Englert » Tue, Nov 09 2010, 8:18AM
Let's not forget that you could've created that with a Display Cube. Draw the profile in the Shape Manager. Then go to the Part Editor, cut the display cube into a cylinder and then sweep the profile around the cylinder. Give it a finish/texture in the Display Part Editor.
No extra programs required. Since you'd already drawn the profile in either AutoCad LT or BobCad you could've created a tool profile with it in the Shape Manager.
Later,
Dennis
Return to “Customer 3D Files”
