Irfanview
Irfanview
Help! I'm trying to open and convert .DWG files from Sub-Zero/Wolf. Irfanview is telling me that I need to purchase CAD Image DLL to view a clear image. It looks to me that that "Plug-In" is already there. Has anyone had any luck converting these files to .stl? It looks like there has been a problem in the past, converting/openning the AutoCad .dwg files.
Brian
Brian
Re: Irfanview
Hi Brian
I am not sure if this would help you in anyway I use ViaCAD.It workers fine I just convert there new out side grill to STL
Can I help you convert what you need for now tell they work it out in Irfanview
Re: Irfanview
Brian,
Irfanview is just an image software. It won't convert Cad files for you. I you talking about Accutrans 3d?
Re: Irfanview
Sorry for the confusion. Irfanview will only convert image files from one graphics format to another and will not convert to .stl. That is another issue. I just found that it won't open a .dwg file without registering/purchasing CAD image DLL. Here is a .jpg of what I see when I try to open a .dwg.
Here are the appliances that I am attemping to convert from .dwg to .stl. I can open in BobCad and convert to .DXF but can't see anything when I open the ,DXF in Accutrans. Any help would be appreciated.
Thanks!
Brian
Thanks!
Brian
- BI-48S_S_3D.zip
- (3.36 MiB) Downloaded 665 times
- 427RG_3D.zip
- (4.31 MiB) Downloaded 650 times
Re: Irfanview
More files
- SO30_3D.zip
- (1.52 MiB) Downloaded 646 times
- RT36_3D.zip
- (3.88 MiB) Downloaded 651 times
- MW24_3D.zip
- (3.91 MiB) Downloaded 655 times
Re: Irfanview
Hi Brian
I converted all of your Zip Files put the forum will not let me download it keeps shutting down
Here are some of Wolf that I have in e-Cabinets right now I just don't have the time to put yours in e-Cabinets today
I am not sure what is going on it will not let me send you any of my Zip Files
Re: Irfanview
Thanks so much George! Maybe later, when you have time, it will work. Email may work better if the forum still does not work...
Thanks Again!
Brian
Thanks Again!
Brian
Re: Irfanview
Wolf App
- 36 single oven - l series.hsf
- (1.05 MiB) Downloaded 661 times
- 1.hsf
- (1.31 MiB) Downloaded 664 times
Re: Irfanview
Wolf App2
- bi-42sd_s 2000.hsf
- (2.42 MiB) Downloaded 672 times
- 427rg_lh.hsf
- (1.25 MiB) Downloaded 647 times
- 427rg _rh.hsf
- (1.24 MiB) Downloaded 658 times
Re: Irfanview
Wolf3
- 48 gas rangetop.hsf
- (2.81 MiB) Downloaded 657 times
- rt36.hsf
- (3.06 MiB) Downloaded 648 times
- mw24.hsf
- (2.69 MiB) Downloaded 664 times
Re: Irfanview
Wolf4
- 36 dual fuel range.hsf
- (3.31 MiB) Downloaded 667 times
- 30 dual fuel range.hsf
- (3.28 MiB) Downloaded 629 times
- d_oven for cab.hsf
- (598.02 KiB) Downloaded 672 times
Re: Irfanview
Wolf6
- 15 in electric cooktop.hsf
- (176.02 KiB) Downloaded 570 times
- 30 in electric cooktop.hsf
- (190.02 KiB) Downloaded 564 times
- 36 in unframed electric cooktop.hsf
- (230.02 KiB) Downloaded 594 times
Re: Irfanview
Thanks so much George! I know how much work that was!
Brian
Brian
