Hi all
I've got a weird issue on my machine. when i try homing the machine when X=0, Z-axis goes up to the high end of the axis causing an e-stop and a simodrive trip.
what can i do to fix this?
best regards
tommy
M67 Homing issue
Moderators: Mike Iubelt, Jason Susnjara, Clint Buechlein, Mike Iubelt, Jason Susnjara, Clint Buechlein
Tommy Nogrady
- Company Name: Protoplane
Ryan Hochgesang
Re: M67 Homing issue
Tommy,
I would recommend you contact our service dept. for further recommendations on how to correct your issue (see email below). It could be a few different things causing issue your seeing. You will want to make sure air pressure is sufficient to the machine as well as bearings properly lubricated. One other thing you may want to check would be to make sure all motor plugs are snug and clean.
email: service@thermwood.com
