Controller freeze at version 6 image when loading
Discuss Thermwood 5-axis Machinery, Controller, and Software.
Moderators: Jason Susnjara, Clint Buechlein, Rich Kasten
SoulDiallo
Postby SoulDiallo » Fri, Jan 30 2009, 5:25PM
Please help us with the following issue:
When starting the controller it freeze after windows has started and the thermwood software is loading (version 6 image)
Then the PC is frozen, even CTRL+ALT+DEL does not work.
Following calls to your tech support
We have :
1- check green fuses, the 2.5A was burned and we replaced it, it is OK now
2- delete log file (plchist.thm, mclock.bin, mclog.bak)
3-re-install thermwood software on C: drive
4- check RAM chip (remove clean, reseat)
5- remove non-essential component on MB (modem, unplug keyboard and DVD drive and use standard external keyboard
6- checked voltages from PC power supply.
None of these worked.
Any other suggestions.
Thanks.
Re: Controller freeze at version 6 image when loading
Postby Ryan Hochgesang » Mon, Feb 02 2009, 10:38AM
Soul,
I have submitted the information you supplied to our Field Service Dept. and they will be in contact with you to help resolve your issues.
Return to “Thermwood 5-Axis Machinery”
