Glass panel door
Moderator: Jason Susnjara
- Company Name: prestige
Glass panel door
How do you create a glass panel door from part editor or how do you load the image for a glass panel door?
Re: Glass panel door
You can get a frame door frame with or without glass in the Door/Drawer selector ( Conestoga ) General Tab bottom left hand corner
Kenny, are you looking for a glass image?
That worked great but I can't get the newly created door applied to my cabinet.Any suggestions?Gary Puckett wrote:You can get a frame door frame with or without glass in the Door/Drawer selector ( Conestoga ) General Tab bottom left hand corner
Originally yes but the other suggestion worked.ThanksRick Palechuk wrote:Kenny, are you looking for a glass image?
Kenny,
Just take your cabinet to the Door/Drawer editor chose the door you want, and click on the opening and the door will be there.
Wow I was ready to pull my hair out then I finally figured out that I had to delete the original doors from the cabinet before the new doors could be imported.Is there an easy way to change the construction material on the entire cabinet?I just realized that I made this cabinet in red oak and the customer is wanting solid cherry.And is there a way to eliminate the toe kick?Gary Puckett wrote:Kenny,
Thanks,Kenny
Yes you can do all that in the cabinet editor on the construction setting tab.
- image.jpg (91.49 KiB) Viewed 8947 times
Thanks that worked great.Gary Puckett wrote:Yes you can do all that in the cabinet editor on the construction setting tab.
