Hole Patterns not deep enough when changing material thickne
- Scott Marshburn
Yesterday we were doing a test for some hardware hole patterns that we needed. The cabinet was created with 3/4 in. material the material was actually 23/32 thick. So when asked if I wanted to change material thickness I clicked yes and changed it from 3/4 to 23/32.The holes were set to 1/32 deep (just for testing).When it drilled the holes it did not touch the material. I went back into eCabinets and edited the same material and changed it to 3/4 thick. This time it went the proper depth into the material. Don't know if this is a Thm control thing or a eCabinets?
- Josh Rayburn
Re: Hole Patterns not deep enough when changing material thi
Hi Scott, can you post a job with this problem?
- Scott Marshburn
Josh I will be try to re produce the scenario that I posted but it will be tomorrow evening as I said I changed the actual material in ecabinets from 3/4 to 23/32 I will have to recreate the same sercumstanceses.Do you need the export from the Cnc? Thanks for your help
- Scott Marshburn
Josh Here Is the Cabinet that I ran Although the material at it's Currents State is eCabinets Generic Material If you change the thickness of the 3/4 thick material to 23/32 when asked if you would would like to change the material thickness then maybe you will get the same results as we did. One note I ran this test from the cabinet editor directly by selecting Cnc from the bottom of the cabinet editor screen Just beside the screen shade slide bare. "Just back tracing my steps."
- JoshTest.hsf
- (436.02 KiB) Downloaded 534 times
