Moderators: Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein , Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein
Gerry A Brown
Posts: 140 Joined: Fri, May 27 2005, 8:56AM
Company Name: Old Style Woodwork
Post
by Gerry A Brown » Mon, Sep 22 2014, 11:53AM
Hello everyone,
I am trying to get a Post P working that outputs Arcs but the router seems to cut all over the place when I run the code that is produced. Could some one please take a look at the code and see what is wrong with it. I have attached the code and the Post P that produced it.
Gerry
Thermwood_CS45-G52L_ARC_inch.txt
(4.43 KiB) Downloaded 1270 times
DRIVE PLATE REEL SIDE arcs.txt
(58.01 KiB) Downloaded 1196 times
Gerry A Brown
Post
by Gerry A Brown » Mon, Sep 22 2014, 3:18PM
Hi,
I should have mentioned we are running this on a 2007 CS45 with 6.1.6.5 control.
Gerry
Daniel Odom
Posts: 204 Joined: Thu, Oct 20 2011, 12:52PM
Post
by Daniel Odom » Tue, Sep 23 2014, 9:18AM
I think arcs need to be incremental instead of absolute.
Brad McIntosh
Posts: 539 Joined: Wed, May 18 2005, 6:59PM
Company Name: CNC Automation
Post
by Brad McIntosh » Tue, Sep 23 2014, 10:01AM
That is correct. Your post is formatted for ABSOLUTE ARC CENTERS instead of INCREMENTAL FROM START ARC CENTERS. Although the post is similar to those of ArtCAM, I am do not have a ready example of what to change the:
VAR ARC_CENTRE_I_ABS_POSITION = [IA|A|I|1.4]
VAR ARC_CENTRE_J_ABS_POSITION = [JA|A|J|1.4]
..reference to.
David Egnoski
Posts: 209 Joined: Tue, May 17 2005, 1:05PM
Post
by David Egnoski » Tue, Sep 23 2014, 10:45AM
It would look like this:
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.4]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.4]
Dave Egnoski
Richmond Cabinet & Millwork
Gerry A Brown
Post
by Gerry A Brown » Tue, Sep 23 2014, 10:52AM
Hi,
I will attempt to get it changed to incremental.
Thanks everyone,
Gerry
Brad McIntosh
Post
by Brad McIntosh » Tue, Sep 23 2014, 11:38AM
Gerry,
Based on David's information and my ArtCAM knowledge, this should do you...
Gerry A Brown
Post
by Gerry A Brown » Tue, Sep 23 2014, 12:45PM
Hi Brad,
Thanks that is greatly appreciated.
Gerry
