Cut through errors
David Giesbrecht
Cut through errors
Post by David Giesbrecht »
code.doc
(31.5 KiB) Downloaded 809 times
Don't know when it started but every once in a while the last side on the pcs the cut through will be way off. See attached, highlighted at the bottom of the code. Notice the height on three sides is -5.63 then the last side is -9.13. (all metric) An ideas???
David Giesbrecht
8.00 GB DDR5 2133MHz
NVIDIA GeForce GTX 970 4GB
Z270x-Gaming 5 MOBO
1TB Samsung 960PRO SSD
Will Williamson
Re: Cut through errors
Post by Will Williamson »
Have you contacted tech support?
Will
http://www.willmade.com
