Jeremy,Jeremy Schiffer wrote:The addition of the ability to have the preliminary outline cuts as climb, with final pass conventional, was a real lifesaver and cut quality improvement. Would it be possible to implement the same strategy for the Single-Pass Tenon Cuts? As it is, they are done in a Conventional cut direction, and when the part is then outlined, there is always a ridge (between the lock dado tenons) caused by deflection (of what? That is another rabbit hole...)
I'm attaching a picture to show what I'm talking about - this causes a gap in the assembled pieces because the Single-Pass Tenon cut is not actually straight, but arcs inward and the back outward as the machine ramps up and then back down during the cut.
If the Single Pass Tenon cut could do a climb first so as to deflect away from the part, then conventional to clean it up, that would fix this issue and make me a very happy camper. Thanks!
Jeremy,Jeremy Schiffer wrote:Hey Clint,
By "the whole edge being cut on a single pass", are you referring to the Single-Pass Tenon? If so, the beginning of it looks just like the end that is shown in the picture, except it has the arc ramp-in. The entire length of the Single Pass Tenon cut is an arc, due to the machine's acceleration and deceleration - therefore the ridge shown in my picture is largest at the center of the cut. Our outline cuts are set to Climb cuts down to the skin thickness, then the final outline thru-cut is Conventional. If I'm misunderstanding you, let me know and I'll be happy to send whatever pictures you may need.
We do see this issue on both the 45 and the 41. It is worse on the 41 though, likely just because of the age of the machine (looser bearings, etc.). But both machines do show this issue in both X and Y direction of cut.
The bit we use for both the tenon cut and the outline cut is Southeast Tool SMDUD551, which is equivalent to the Vortex 3185XP.
The Single Pass Tenons are run at 18,000 RPM, 315 IPM.
The Outline cuts are at 18,000 RPM, 630 IPM.
Thanks for looking at this!
Shall I rename them to .txt files and post here?This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
cabinets@thermwood.com
host relay.is.cc [209.159.152.170]
SMTP error from remote mail server after end of data:
550 This message was classified as rSPAM and may not be delivered
Hard to tell, because the material thickness change during TWD creation causes all the parts to be oddball sizes. If I measure the part from the bottom, it measures consistently. Measuring from the top, obviously the part tends to get narrower as you move toward the center of the cut.Also, when you measure the part, which one has the correct measurement? Within the tenon or outside the tenon? Or neither?
