HELP offset error
Jason Rains
HELP offset error
Postby Jason Rains » Mon, Nov 09 2009, 8:03AM
Hi guys, I need some help adjusting my offset settings. When I try to set my offsets an error occurs and shuts down the program. Any suggestions?
Ryan Hochgesang
Re: HELP offset error
Postby Ryan Hochgesang » Mon, Nov 09 2009, 8:17AM
If you are using the G52L# method for offsets, it is likely your offset table has been corrupted. To correct this issue, you will need do the following once you've written down any offsets that you can access in the table:
Shutdown the Thermwood software > Go to Windows Explorer > find C:\offset.tab directory, Delete file THM.OFF > Then restart the Thermwood software and you should be able to enter values in the offset table.
Jason Rains
Postby Jason Rains » Mon, Nov 09 2009, 9:03AM
Thanks Ryan, I'll try it.
