Call label does not exist
DanFecteau
Post by DanFecteau »
When I load a file that I already started to machine and I want to start to a double digit sheet I get "call label does not exist" ???
Thank you.
jason galbraith
Country: AUSTRALIA
Re: Call label does not exist
Post by jason galbraith »
Me too, but our control nesting software is old, so maybe that is it?
www.eastcoastultimate.com.au
DanFecteau
We use 5.58, the latest..
Ryan Hochgesang
Post by Ryan Hochgesang »
If you could please sent me a copy of your machine MSU text file, I will have a look to see how the label scan is set on your particular machine. The text file is located in the following location: C:\Msufmt\"machinename".MSU
Also, I will need to see a copy of your THMMSU.BIN file that is located in C:\System directory.
You can email the files to: program@thermwood.com
Brad McIntosh
Company Name: CNC Automation
Post by Brad McIntosh »
Dan,
I would assume that you did not have this issue BEFORE your Hard Drive Retro... Am I correct?
There is a setting in the machine MSU that instructs the controller to scan the complete program for CALL LABELs (M80L#). Back when you machine was first released, this setting was set to NO. CNC Automation probably changed the setting to "YES" back around 2006 to accommodate your use of Control Nesting. The MSU was recompiled and updated to your THM SYSTEM directory.
When your "COLLECTOR" files were sent in for your recent hard drive retro, it is possible that this modified MSU (compiled .BIN) was not applied to the newly configured hard disk drive.
Ryan will probably confirm this when you send him your MSU (c:\msufmt\C40-344.MSU) and the compiled BIN version c:\system\thmmsu.bin. It should then be easy for him to update this for you.
If we can be of assistance, let us know....
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
jason galbraith
Country: AUSTRALIA
Thanks Ryan, applied the update this morning and it is now running from sheet 9 onwards, whereas before it would lock up.
Ryan Hochgesang
Thanks for the update Jason.
Marius Gouws
Company Name: Plett Roofing
Country: SOUTH AFRICA
Post by Marius Gouws »
Good Morning Ryan
Can you send me the update as well. The manual say that the program can not see a label after the 5000th line of code. Very frustrating if you do carvings and at the end of the carving program ,when all it needs to do is a parameter (outline) cut, pics up the tool and up comes the error message "Call label does not exist".
If I change the C40-482.MSU file where it says "Full Label scan" from "no" to "yes", will that sort it out?
Thanks in advance
Marius
Ryan Hochgesang
Marius,
Yes, I can change your MSU setup as well.
I will need the following files from your machine in order to make changes:
1.) The MSU text file located in: C:\Msufmt\"machinename".MSU
2.) The MSU BIN file located in: C:\System\"THMMSU.BIN"
You can email the files to: program@thermwood.com and refereence this forum posting.
Marius Gouws
Good morning Ryan
I have e-mailed the requested files to the given e-mail address.
Thanks very much
Marius
PS: Good Luck to the "Springbucks" on Saturday when playing the "All Blacks"
Hope things go better than last Saturday
Ryan Hochgesang
We have recieved your files and will make the necessary changes and send you the udpated files.
