Melamine 2nd pass problem
Jason Rains
Postby Jason Rains » Mon, Feb 21 2011, 4:15PM
I am using a CS45 to cut melamine closet components from DXF files, among other things. The router machines properly leaving the .025" skin I have set but as it cuts the 2nd pass it does not cut the skin even with the side of the part. I don't have any cleanup amount set so I don't think that is an issue. Any ideas on why this is so?
Jason
Gary Campbell
Re: Melamine 2nd pass problem
Postby Gary Campbell » Mon, Feb 21 2011, 8:31PM
Jason...
My guess is that you have either machine or tool deflection on an aggressive 1st pass that is causing a slight over cut, resulting in slightly undersize parts. The skin pass, since its under little or no load cuts in the proper location, leaving the skin slightly proud of the part.
Gary Campbell
Ryan Hochgesang
Postby Ryan Hochgesang » Tue, Feb 22 2011, 8:28AM
Sometimes changing the cut convention from Climb to Conventional or visa versa will help reduce the cutline that you sometimes get with double pass parts and tooling deflection.
BenRatt
Postby BenRatt » Mon, Mar 21 2011, 1:24PM
I"m having this issue more lately as well. I''m using a 3/8" bit. Are you using a 3/8" bit or a 1/2" bit? Ryan from your experience a 1/2 compresion would deflect less correct?
Ben Ratterree
Blue Ridge Cabinetworks
Spartanburg, SC
http://www.blueridgecabs.com
Company Name: Halls Edge Inc
Postby Josh Rayburn » Mon, Mar 21 2011, 3:39PM
1/2" tools will deflect less. You could also slow down the feed rate for the 3/8" tool and you will be fine. It is also beneficial to set a max pen at about half the material thickness as long at it clears the upshear portion of your compression tool.
