Thermwood / eCabinet Systems • View topic - cutting laminate
  • Advertisement
cutting laminate
Moderators: Jason Susnjara, Rich Kasten
cutting laminate
Postby darren m harvey » Sun, Jun 19 2011, 8:51PM
has anybody cut laminate on their router? if so what bit or bits did you use and at what speed. thanks, Darren
darren m harvey
Company Name: coastal woodshop
Re: cutting laminate
Postby Ryan Hochgesang » Tue, Jun 21 2011, 7:41AM
Hi Darren,
You can go to Thermwood's woodworkers whole sale site to see compression tools as well as other types:
http://www.woodworkerswholesale.com/
Typically a compression tool is used for cutting laminates to help reduce chip out. The Compression tool has both an up and down spiral on it which pull chips to the center. You will need to be careful with this type of tool, be sure not to perform frequent plunge operations, such as in a drilling scenario. Frequent direct plunge operations can cause the bit to heat up and potentially cause a fire. If you will have frequent plunge operations, such as in a drilling routine, then it is best to use an up spiral type tool.
As for feeds and speeds, you will have to work with this some for your particular material, but if you have good hold down you should be able to start with a spindle speed of 18000 RPM and cut feed speeds of approx. 500 - 600 IPM.
Ryan Hochgesang
Software Support
Ryan Hochgesang
Postby Will Williamson » Tue, Jun 21 2011, 9:28AM
You need to clarify are you cutting just the laminate 1/16 or 1/32 or is the laminate glued to a substrate
Will
http://www.willmade.com
Will Williamson
Postby Ryan Hochgesang » Tue, Jun 21 2011, 10:11AM
Yes, Will has a good point that I didn't consider. I was assuming that your cutting sheet goods with a 1/2 - 3/4" thickness that had been laminated on either side.
Ryan Hochgesang
Software Support
Ryan Hochgesang
Postby darren m harvey » Tue, Jun 21 2011, 8:41PM
thanks for the reply guys. and yes it's laminate.
darren m harvey
Postby Will Williamson » Wed, Jun 22 2011, 9:32AM
I would use a 1/8 down spiral single flute. buy a half dozen , and start at 300 IPM and then experiment, run it up till you break a cutter and then back it off 50 IPM
Will
Will Williamson
Postby Terry Davis » Mon, Jun 27 2011, 7:36AM
We cut laminate all the time, face down with a 3/16 down spiral so that the bit don't lift the laminate.
Terry Davis
Company Name: Penn Laminates
Return to Thermwood 3-Axis Machinery
