Georgi,
No fear of me running my machine that long. I thought that was interesting about the Busch pumps though. Not something you want to find out after the pump has seized
Gerry
How long can the Machine Run for?
- Company Name: Old Style Woodwork
Re: How long can the Machine Run for?
After 4 years on our first CNC and 3 years on our second CNC we finally set up maintenance check on our 3 Busch pumps. We have double 10HP on our old machine and single 25Hp on the newer machine. The need came from a lose wire that was drawing too much power and tripping the switch. We got the oil and filter changed as well. Just to give you an idea how though those pumps are. This maintenance should have been done 2 years ago.Gerry A Brown wrote:Georgi,
Gerry
Since then we've set up annual maintenance on the pumps with Busch Canada. The two CNCs are the only thing in the shop that can't stop running so spending the money on maintenance will eventually pay off.
Top Notch Cabinets
Hey Georgi, Whats the managers name? Not George by any chance? Does he own a wide brimmed hat?
Getting serious now. With my pumps they seem to be always under working conditions. So when you apply the valve to the bed its still working as hard when the valve is turned off. When you power down the pumps, even though are not switched on to the bed they stop rotating very quickly. My old cnc had them open to the air when valve was off to the bed so they just sucked free air and they seemsed to work easier. When turned off in that situation they slow spun to a stop.
Is my setup the same as yours?
Regards
Neville
Regards
Neville
Neville Australia
Neville, I couldn't catch the first part of your reply. I sense joke but it might be cultural. I guess when you see my name you can guess that English may not be my fist language. Anyways I am fresh off the boat as you may refer.
Anyways to the question. I can't really compare as we have the same setup on both machines but it seems ours is more like the latter case in your reply. It works easy when the valve is off (no vacuum in the table).
Top Notch Cabinets
