installing update
Jason Stephenson
Company Name: Marks Joinery
installing update
Postby Jason Stephenson » Tue, Sep 06 2011, 6:07PM
hey guys just wondering we just installed update 5.66 it worked but said we needed a profile module is the update still ok to run
Cheers
Company Name: Halls Edge Inc
Re: installing update
Postby Josh Rayburn » Wed, Sep 07 2011, 6:03AM
Try opening Profile Modeller and choose a default tool group.
Ryan Hochgesang
Postby Ryan Hochgesang » Wed, Sep 07 2011, 8:41AM
You will need to take note of the following information on the update page:
IMPORTANT: As of version 5.60 and on you MUST have Profile Modeler installed to update Control Nesting. You must also have THM (Windows 2000 system version - 5.05, Build 9 or higher) OR (Windows XP Pro system version - 6.1.0.4 or higher)
If Control Nesting is not on your controller, you will need to contact Thermwood's retrofit dept. for the upgrade. You can email me your company name and machine serial number and I can check records here at THM to see if PM has been released for your control at any point in time. Email: program@thermwood.com
Marius Gouws
Company Name: Plett Roofing
Country: SOUTH AFRICA
Postby Marius Gouws » Wed, Sep 14 2011, 10:34AM
Good Afternoon
After updating CN, when I click on load in CN I get the following: "Invalid database, GetRows binding Error" Then job listing is empty and I have to redirect and reselect to the job file (.twd). Select material filter, click "OK" , oops forget something, click on load again, same error, job listing is empty, have to reselect it.
Can help me?
Thank you very much in advance
Marius
www.jirehcustominteriors.co.za/
Ryan Hochgesang
Postby Ryan Hochgesang » Thu, Sep 15 2011, 7:43AM
Did you make sure and shut down the THM software prior to running update? You will need to run update file again and choose REMOVE, then run again to install.
Also, verify your THM software version as stated at the top of download web site:
Postby Josh Rayburn » Thu, Sep 15 2011, 7:52AM
Ryan,
Is there a point at which the minimum requirements will change past THM version 5.05?
Ryan Hochgesang
Postby Ryan Hochgesang » Thu, Sep 15 2011, 9:15AM
THM minimum requirement will likely only move upward as time goes on with later versions of control nesting. Similar to what has been seen with current requirements:
THM (Windows 2000 system version - 5.05, Build 9 or higher) OR (Windows XP Pro system version - 6.1.0.4 or higher). I would think it will be quite some time, however likely due to changing computer technology.
Users browsing this forum: Bing [Bot] and 9 guests
