Top to Stretch - Dado cut on wrong side
JohnLashuay
Post by JohnLashuay »
Hi guys,
Here are 2 cabinets that looked good up until they were cut. In both situations the TOP had s stretch blind dado'd to it. When cut, the dado was on the opposite side than what it should have been.
Can someone take a look at these for me?
Thanks, John!
Montfort--Vanity.hsf
(876.02 KiB) Downloaded 356 times
http://www.rylexonline.com
Thermwood CS 43
JohnLashuay
Re: Top to Stretch - Dado cut on wrong side
Here is the second cabinet.
Bangle Pull Out.hsf
(1.09 MiB) Downloaded 330 times
Thermwood CS 43
Company Name: Halls Edge Inc
Post by Josh Rayburn »
Looked.....can't find a probelm?
I have not written any code for it to reverse plot and see what happens though....
maybe this afternoon I'll have a chance to look further into it...
JohnLashuay
Thanks Josh! Everything looked normal until we cut it. Interesting that it happened on 2 different cabinets involving a Top to Stretcher blind dado construction.
Thermwood CS 43
Yep it's a strange one indeed.
Hope TWD can shed some light on it, and I also hope it doesn't bite me anytime soon...there are just too many things that need fixing in this software right now; the broken list just keeps getting longer and longer!!
JohnLashuay
Thanks Josh!
Thermwood CS 43
Georgi Baltov
Post by Georgi Baltov »
I reported something like that in the beta forum. Scott knows about it and mentioned it's going to be fixed in the next release. Mine was a full dado that looked good in eCabinets but was cut on the opposite side on the machine
JohnLashuay
Thanks Georgi! Good to hear!!
Thermwood CS 43
Daniel Bell
Company Name: Central City Millworks
Post by Daniel Bell »
I also had similar problem with a deck dadoing into a partition rather than an end. Part looked great in Ecab, but dado was put on wrong side of partition in control nesting. I think adjusting the thickness of the material is what confused the software, because when i sent it out as is without changing thickness i had no problem. Sorry you're having this issue, but I feel better knowing maybe its more than just my incompetence with Ecabinets :D!
