Problem Trimming Flip-Ops First
A problem has occurred after updating to Control Nesting V5.66
Under Flip Ops First I select Cut Flip Operations First then Trim Sheet and then select Pin Area Only
When I look at the code it is trimming 3 Sides Not just the pin area
I then notice I can select more than one radio button in the flip ops first dialog
Joe Harger
Re: Problem Trimming Flip-Ops First
Post by Joe Harger »
Kerry, this problem has been reported to the programmers and a fix for it should be available next release...I have talked with Keith as well and let him know.
Joe Harger
Software Support
Thermwood Corporation
Thanks Joe,
Keith would like to revert back to the previous version of control nesting. Is that possible?
Joe Harger
I have talked with Keith and we have already discussed that and he is going to wait until the release. I will keep in contact with him and if the release takes longer than he likes then I can
help with his previous version.
Joe Harger
Software Support
Wayne Adelkopf
Company Name: Noble Woodworks Inc.
Post by Wayne Adelkopf »
Kerry,
Curious, why do you trom 3 edges?
Wayne,
I only want to trim the pin area of two edges but after updating control nesting to version 5.66 that is broken.
If I selected Trim Pin Area only the machine did not trim anything.
