x axis error
Alex Bowler
Company Name: cutshop
Country: NEW ZEALAND
x axis error
Postby Alex Bowler » Wed, May 16 2012, 3:55AM
Hi,
I need to cut a part that is right at the edges of the sheet (I can only leave 2 mm each side) and i am getting a x axis out of bounds error at machine.
I have the nest to edges option selected and a collar of 2mm, when I graph the job no error comes up, it will start cutting then stop and the
X axis error will come up. I assume it is to do with the part being at the edge of the bed but I have to keep it at that size and i cannot see any
Physical reason for it not to be able to.
Thom Davies
Company Name: Dawn Group
Re: x axis error
Postby Thom Davies » Wed, May 16 2012, 2:43PM
In Ecabinets set the material to be bigger than it really is, e.g 1225mm wide and 2445 Long etc.
Also you dont want to have a 2mm collar as that moves the panels in 2mm from the edge and with nest to edge it kinda like a double negative.
[url=http://www.colinmcraesport.com]
[/url]
Users browsing this forum: Bing [Bot] and 3 guests
