Problem With offfalls cutting into parts
Jason Stephenson
Company Name: Marks Joinery
Postby Jason Stephenson » Wed, Jun 27 2012, 6:45PM
We are currently cutting a job out that has some grained board as well as ungrained board and have been having a problem with the cutter cutting into the parts when it cuts the offfall only on the grained board though just wondering whether there is any way to fix this problem? It is only hitting the part by about 1 to 2mm but causing us heaps of hassle ie doors are to short
Daniel Vonderheide
Re: Problem With offfalls cutting into parts
Postby Daniel Vonderheide » Thu, Jun 28 2012, 7:22AM
Jason,
Send your export and the cnc file to program@thermwood.com along with the description you posted above of the error. We will look into it.
Daniel Odom
Postby Daniel Odom » Thu, Jun 28 2012, 7:28AM
edit: nevermind
Brad McIntosh
Company Name: CNC Automation
Postby Brad McIntosh » Thu, Jun 28 2012, 10:31AM
Daniel,
It would be nice to know what the issue was...??
Daniel Odom
Postby Daniel Odom » Thu, Jun 28 2012, 2:11PM
Oh, I just had a similar issue but it was with grouped doors; turns out I had the bit diameter variable in Ecabinets true shape nesting as having a different diameter than what I was using at the machine as my outline tool, this caused some doors to be cut the wrong size. This sounds like some other issue though; it was early and I read through the post too quickly.
Daniel Vonderheide
Postby Daniel Vonderheide » Thu, Jun 28 2012, 2:39PM
I still have not received files from the original poster.
