Pre ramp plunge and ramp length for key hole
Scott Marshburn
Postby Scott Marshburn » Sat, Sep 29 2012, 6:19AM
I was wandering if there was a way to control the pre ramp depth and ramp length for a individual tool. We have a job (DXF) that has several layers that benefit from the ramp settings but the client wants to add a key hole cut to the parts. Although we have not actually ran a part yet I can guess that this type of cut would require a special ramp setting Has any one done this type of cut If so what type of settings did you use?
Scott Marshburn
Re: Pre ramp plunge and ramp length for key hole
Postby Scott Marshburn » Fri, Oct 05 2012, 6:01PM
Ok maby I shoud make this a new feature frquest. That is to apply pre ramp plung and a ramp in lingth per tool.If needed
Company Name: Halls Edge Inc
Postby Josh Rayburn » Mon, Oct 08 2012, 7:11AM
Hi Scott,
The only work-around that has been successful is to isolate that one keyhole operation and nest the same sheet twice. Once with the settings to cut the keyholes - nest it with ramp settings changed, let them cut, stop the router before it cuts the outlines. Then load program 2 which is the rest of the machining with ramp settings normal and no keyholes. As long as the outlines of the parts are identical, the nest will be identical.
Users browsing this forum: No registered users and 7 guests
