Hello everyone,
I am trying to get a Post P working that outputs Arcs but the router seems to cut all over the place when I run the code that is produced. Could some one please take a look at the code and see what is wrong with it. I have attached the code and the Post P that produced it.
Gerry
Arcs Post P problems
- Company Name: Old Style Woodwork
- Thermwood_CS45-G52L_ARC_inch.txt
- (4.43 KiB) Downloaded 458 times
- DRIVE PLATE REEL SIDE arcs.txt
- (58.01 KiB) Downloaded 427 times
Re: Arcs Post P problems
Hi,
I should have mentioned we are running this on a 2007 CS45 with 6.1.6.5 control.
Gerry
Gerry
I think arcs need to be incremental instead of absolute.
That is correct. Your post is formatted for ABSOLUTE ARC CENTERS instead of INCREMENTAL FROM START ARC CENTERS. Although the post is similar to those of ArtCAM, I am do not have a ready example of what to change the:
VAR ARC_CENTRE_I_ABS_POSITION = [IA|A|I|1.4]
VAR ARC_CENTRE_J_ABS_POSITION = [JA|A|J|1.4]
..reference to.
..reference to.
It would look like this:
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.4]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.4]
Dave Egnoski
Richmond Cabinet & Millwork
Hi,
I will attempt to get it changed to incremental.
Thanks everyone,
Gerry
Thanks everyone,
Gerry
Gerry,
Based on David's information and my ArtCAM knowledge, this should do you...
Hi Brad,
Thanks that is greatly appreciated.
Gerry
Gerry
