Last line feed speed
Dave Burtchell
Postby Dave Burtchell » Tue, Jan 10 2006, 6:30PM
Howdy,
I'm using 4.86. I have Last line feed speed set to 300. Outline tool feed speed is 800. I've been getting a lot of parts with the last line feed speed of 800. Anyone else seeing this?
Dave
Postby Ryan Hochgesang » Wed, Jan 11 2006, 11:44AM
Hi Dave,
Go into your Control Nesting SETTINGS and check to see what the \"Min Feed Rate\" (Located two down from \"Last line feed speed\" )is. I'm guessing that it says 800. This setting will be the slowest feed allowed to be posted in cnc program.
Postby Ryan Hochgesang » Wed, Jan 11 2006, 11:45AM
Hi Dave,
Postby Ryan Hochgesang » Wed, Jan 11 2006, 11:46AM
Sorry about the double reply.
Mouse got stuck I guess :)
Dave Burtchell
Postby Dave Burtchell » Wed, Jan 11 2006, 5:02PM
Ryan,
Min feed rate is set at 100!
Dave
Postby Ryan Hochgesang » Thu, Jan 12 2006, 9:42AM
Dave,
Try updating to the latest version 4.87 and see if you are still seeing the issue. I had posted a program through 4.87 and it looked good. If you still see the issue, please sent me the file that you are nesting along with the following files from your machine:
C:\\RollingNest\\machine.ini
C:\\RollingNest\\tools.thm
C:\\system\\toolman.thm
Dave Burtchell
Postby Dave Burtchell » Sat, Mar 25 2006, 9:45AM
Ryan
Thanks to you and your team for the 4.90 fix of the \"last line feed speed\" problem. Would you please revisit it again and look at the next to last line? I'm seeing 800 ipm showing up there instead of the last line.
Dave
Postby Ryan Hochgesang » Mon, Mar 27 2006, 4:33PM
Hi Dave,
I will make up some sample files to try and see this issue. I'll get back to you asap.
Postby Ryan Hochgesang » Tue, Mar 28 2006, 10:48AM
Hi Dave,
I've tried to reproduce the situation that you are explaining, but have been unable to do so. The only thing that I might add, I've been testing in V4.91, this may be the difference. If you still see the issue after updating to v4.91, I would like to see the following files:
- .hsf (cabinet file) or .esa (Assembly file)
- .twd file that you are using from ecab
- .cnc file that you've generated at CNC machine
- C:\\RollingNest\\machine.ini (From Thermwood Controller)
- C:\\RollingNest\\tools.thm (From Thermwood Controller)
- C:\\System\\Toolman.thm (From Thermwood Controller)
