DXF will not load
Stuart Douglas
DXF will not load
Post by Stuart Douglas »
Ive made and remade this dxf file that contains some text for a 2D sign. When I bring it into CN it locks the computer. Hard. Every time. Not sure what I have done wrong or what is causing it. Any help is appreciated, I've been tryin to get this cut for almost a week. :wall:
casadomenica.zip
(164.62 KiB) Downloaded 536 times
_____________
NVME SSM2HD 1TB NTFS
Clint Buechlein
Company Name: Thermwood Corp
Re: DXF will not load
Post by Clint Buechlein »
Stuart,
That's a lot of entities. There are nearly 8000 on you chaincompout layer and almost 1300 on you chaincompin layer. With that number of entities Control Nesting is going to have a hard time processing it regardless the age of your machine. I would suggest trying to redraw eliminating as many line segments as possible. I'd take a guess that it started with polylines and whatever output it, broke it into segments for you.
Stuart Douglas
That's correct. It was a stylized text that I scaled and fit in AI, then saved as DWG for ACAD. I weeded points in the polyline down to about 1/16th of an inch to preserve the shape and form, then converted from polyline to line segments because CN doesn't like polylines. Is there a better way? I do a project like this with increasing regularity now. Is there an upper threshhold for point density that CN will tolerate? I allowed CN to try and load this file for about 5 minutes in each instance, thinking it would eventually get it (I understood that it was a lot of points) but it hangs proper every time. Not really sure what to do next. I'll try and reduce the number of points by half, but I'm not convinced it is the point count that is causing the hang yet.
_____________
Larry Epplin
Post by Larry Epplin »
Control Nesting has to iterate through all the entities to piece together an operation. I found some bad geometry at spots on your dxf. I modified the drawing by putting in a few long lines and correcting the non-connected spots with bad geometry. I also segregated each chain for it's own layer. It still takes some time, but it works. The more simplification you can do the better. I've attached a new file for you to try.
CASADOMENICA_modified.zip
(155.77 KiB) Downloaded 508 times
Larry Epplin
Just a note. You might get some errors for "appropriate start point not found". They should not hurt your result. Simply click OK on them.
Will Williamson
Post by Will Williamson »
Go buy your self a copy of V Carve pro it will pay for itself in a couple of days.
Will
http://www.willmade.com
Stuart Douglas
Will Williamson wrote:Go buy your self a copy of V Carve pro it will pay for itself in a couple of days.
I've been on the fence for while about this software, but have never had a competent person demo it. It looks like great software. I guess its time to put on the headset and roll through the tutorials.
_____________
Stuart Douglas
Larry Epplin wrote:Control Nesting has to iterate through all the entities to piece together an operation. I found some bad geometry at spots on your dxf. I modified the drawing by putting in a few long lines and correcting the non-connected spots with bad geometry. I also segregated each chain for it's own layer. It still takes some time, but it works. The more simplification you can do the better. I've attached a new file for you to try.
Thanks Larry!
I cut this yesterday. I'll be painting it up today and, winter weather willing, hanging it early next week for my client.
I've a friend who has recently bought a Shark, which I understand comes with a desktop version of Vectric VCarve, so it looks like I will be diving in to the hours of tutorials over the holiday break. The DXF method is just not as full function as I had originally believed. Great in a pinch for small or one-offs, but the more work I get like this, the more I think I'll have to bite the bullet and work with the Vectric software.
_____________
David Giesbrecht
Post by David Giesbrecht »
I have used a program like Bobcad to explode polylines to arc's which trims down segments big time.
David Giesbrecht
8.00 GB DDR5 2133MHz
NVIDIA GeForce GTX 970 4GB
Z270x-Gaming 5 MOBO
1TB Samsung 960PRO SSD
David Giesbrecht
David Giesbrecht
Z270x-Gaming 5 MOBO
