in control nesting load a job with a few pieces on the sheet that will leave a big off fall then nest the job. then go to edit ----> nesting parameters and check off make off fall square. doesn't do anything even if you nest the job again x or y.
every other setting seems to work like nesting start point and collars.
control nesting bug involving square off fall
NVIDIA GeForce GTX 950
http://www.trueform.ca
CS43 cnc
CS43 cnc
Re: control nesting bug involving square off fall
Thomas,
Can you post an export from Control Nesting? Mine seems to be operating correctly so I'd like to see what settings you have different than I do.
here you go
there is a cab file in the zip folder only way I could attach it. I can make a video if you need as well
- control nesting export.zip
- (114.56 KiB) Downloaded 412 times
CS43 cnc
CS43 cnc
Thomas,
Got it sorry. Helps if I read your post better. Missed the part where you said go to Edit, rather than going into Settings, then Nesting Parameters. Sorry for wasting some of your time. We will get it listed and fixed.
no problem. I just found out about doing it this way as its a bit of a time saver
CS43 cnc
CS43 cnc
