Machining plam on 1 1/2'' particle board
DanFecteau
Postby DanFecteau » Fri, Jan 26 2018, 2:09PM
I have 160 vanities to produce and they are mostly made of 1 1/2'' thick particle board with plastic laminate on both sides. I was wondering what tool do you guys use, feed, rpm, etc.... I've had bad results in the past, only able to cut couple sheets before having bad quality cuts...
Thomas strembitsky
Re: Machining plam on 1 1/2'' particle board
Postby Thomas strembitsky » Fri, Jan 26 2018, 2:14PM
that sounds like a fun project.... I would use a half inch compression and do it in either two or three passes.
NVIDIA GeForce GTX 950
http://www.trueform.ca
CS43 cnc
Ian Richardson
Company Name: Millworx
Postby Ian Richardson » Mon, Jan 29 2018, 8:58AM
Make sure your flute length is long enough to cut 1 1/2"
