door not getting profilfed randomly
Thomas strembitsky
Postby Thomas strembitsky » Tue, Feb 20 2018, 3:05PM
I was cutting some single pass mdf doors today and I had a 2 random doos get cut as a blanks with no profiling done to them... has anyone else had this happen? I'm attaching the picture of the nest along with the graph view showing it not getting a profile. also attaching the actual cnc code. I can give the ecabinets file and twd if needed
its part 4 keep in mind that the file is rotated 180 degrees
cnc file.zip
(8 KiB) Downloaded 27 times
NVIDIA GeForce GTX 950
http://www.trueform.ca
CS43 cnc
Tommy Wieler
Re: door not getting profilfed randomly
Postby Tommy Wieler » Fri, Mar 09 2018, 1:03PM
Thomas,
We had the same problem, where doors were randomly not getting profiled.
Are you using the latest version of Control Nesting? If so, TADA! Found your problem.
Seems like Thermwood messed up something in that update. We rolled back to the previous version, and problem was solved.
To roll back, just go back to your downloads folder and locate the installer for ControlNestingSetup_6.0.4.18. If you no longer have it, I could get you a copy.
Thomas strembitsky
Postby Thomas strembitsky » Fri, Mar 09 2018, 4:11PM
okay ill roll back my version and keep an eye out for it happening
CS43 cnc
Clint Buechlein
Company Name: Thermwood Corp
Postby Clint Buechlein » Mon, Mar 12 2018, 11:31AM
I see the same here and will get it listed for the software engineers to look at.
Tommy Wieler wrote:Thomas,
When did you notice the issue? The sooner we know there is an issue, the sooner we can correct it.
Tommy Wieler
Postby Tommy Wieler » Mon, Mar 12 2018, 12:31PM
Noticed this issue the first time we attempted modeling doors after the latest control nesting update
