Profibus
Moderators: Jason Susnjara, Larry Epplin, Clint Buechlein
Marius Gouws
Company Name: Plett Roofing
Country: SOUTH AFRICA
Profibus
Postby Marius Gouws » Wed, Jul 25 2018, 1:30PM
Good evening.
We are getting the following error: Siemens feed module fault (via profibus)
Z axis feed module faulted.
Also on the Siemens encoder inside the cabinet the red light is on.
If I unplug the profibus cable from the pci card the red fault light on the encoder stay off.
Any ideas?
The error code on the Siemens encoder reads: E A504
Thanks in advance
Marius
Rayno von Schlicht
Company Name: Rind Routing Services
Re: Profibus
Postby Rayno von Schlicht » Thu, Jul 26 2018, 1:50AM
Morning Marius
Have you been able to resolve this issue?
I have had a similar issue on my Model 40.
Removing the profibus card ( the one in the PCI slot with purple cable ) and reseating it could help.
Sometimes there is just a bad connection.
This could happen if the control cabinet was moved or bumped by mistake.
Good luck!
Marius Gouws
Re: Profibus
Postby Marius Gouws » Thu, Jul 26 2018, 2:57AM
Hello Rayno
I took the pci card out about 3 times, spray and clean it with "Electro Kleen". As soon as the super Control start up, the fault light on the Siemens profibus (encoder) comes on.
This is also a C40 model, that Jireh bought new from Thermwood in 2006.
I tried to move the pci card to another pci slot, but then you need the drivers again, which I do not have. I will have a look on the internet for the drivers.
We are trying now to get another card to test.
Rayno von Schlicht
Re: Profibus
Postby Rayno von Schlicht » Thu, Jul 26 2018, 3:21AM
IF you struggeling and dont come right, try emailing Jeff at Thermwood (JRMeece@thermwood.com) directly as he might have some other tricks to try.
I could be a faulty motherboard, which I hope its not.
Hope you have some success.
Brad McIntosh
Company Name: CNC Automation
Re: Profibus
Postby Brad McIntosh » Thu, Jul 26 2018, 9:46AM
I would suggest calling or emailing Thermwood's Technical Service Department.
Technical Service: 1-800-221-3856
service@thermwood.com
They should be able to help you.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Users browsing this forum: Bing [Bot] and 21 guests
