Part editor problem when machining
Postby DanFecteau » Fri, Jan 27 2006, 8:38AM
When I nest in eCab I clearly see my pattern on my top stretcher front but in the rolling nest I don't have anything, and the machine does't rout it so why ?? Thanks
(179.99 KiB) Downloaded 87 times
Josh Meyer
Postby Josh Meyer » Fri, Jan 27 2006, 2:44PM
In order for us to troubleshoot your cabinet we will need the hsf file. If it is an assembly we will need the esa file. These files are saved in the eCabinets folder on the C(root) drive of your computer. You can also put the cabinet/assembly in a room layout and save that job at which point you could send us the esj file. The esj file you have attached to your post is a job file created from a batch of cabinets and the individual cabinet information isn't contained in an esj file saved this way. Sorry about the confusion!
