Fixture offset changes Model CS-45 WinXP vs. C-50 Win7
Richard White
Company Name: TaylorMade Systems
Postby Richard White » Mon, Aug 05 2019, 1:33PM
Not sure of the version, but I think it is 6.
Here we go, we now have 2 routers, one is an older C-50 that was upgraded to Win7. This newer machine runs on XP I think. Anyway, on the older C-50 machine we were able to change the fixture offset to accommodate each individual fixture placed on the table. I think that is because the controller was upgraded.
I am not able to do that on the CS-45 machine. I can get to the screen, input numbers, but no choices on saving said changes. We have about 75 programs or so, and each must be on its own offset or things get ugly quick. We do very little wood cutting but more aluminum machining, very light machining. It works, this CS-45 has a tool changer which will be the cats meow.
Any advice? I believe they are planning to upgrade to a newer version.
Richard
Will Williamson
Re: Fixture offset changes Model CS-45 WinXP vs. C-50 Win7
Postby Will Williamson » Sat, Aug 10 2019, 6:33AM
Set the fixture offset and then push F10 then then press Y to keep the changes.
Will
http://www.willmade.com
Richard White
Postby Richard White » Mon, Aug 12 2019, 4:57AM
Will,
Thank you for that critical piece of info, seems that is not written anywhere in the manual.
Now we are cookin...
Thanks again..
Richard
Daniel Vonderheide
Postby Daniel Vonderheide » Wed, Aug 14 2019, 8:01AM
Richard,
Which manual are you looking at? I have checked back to an old 91000 Super Control user manual, version 5.05, (the big blue book) and the information for setting the offset is complete inside of it.
Richard White
Postby Richard White » Wed, Aug 21 2019, 11:05AM
Daniel,
This is a case of not looking thru enough pages. I did in fact find where one needs to press F10.
This control is much different than our C50 which has been upgraded.
Thanks for looking into this.
Richard
